I'm looking for some Ideas (pictures) to securely mount the 2 fuse boxes, Mine both ended up together under (what will be) the dash. I just successfully started the car for the first time and need to secure things for the first Go-Cart run!!
here is how I mounted my 'inside' fuse box under the dash. It is towards the passenger side :
Bracket looking down from over dash:
Bracket looking up from under dash:
Installed bottom view:
Installed top view:
The fuse box is hidden by the dash (looking at it from passenger seat level):
hope this helps!
