Results 1 to 5 of 5
Thread: IRS Pin Drive Trigo fitment problem...
    Atlanta, GA
    Hello all, and thank you in advance for any helpful replies. I'm assembling a pin drive width IRS and it's time to mount the wheels (15" Trigo FIAs.) When I slide the Trigo adaptor onto the new Ford Racing 5-lug kit car IRS hub, the studs are so long that the pin nuts cannot be tightened fully onto the adaptor. I have included pictures. Am I missing something here? Is a spacer required? I've seen no mention of this anywhere. I'm assuming it's operator error at this point. Ideas?
    Senior Member Bren's Avatar
    Dec 2013
    Build: Sugar Land, TX; Live: Madison, WI
    First, you're going to want to put your brake rotors on. Also, you're going to need to grind down/cut off the non-threaded parts of the lugs.
    Build Blog
    #8203, carbed 427W (611 hp), TKO 600, IRS
    Delivered: May 27, 2014
    Mechanically "Complete": October 1, 2014
    Atlanta, GA
    Thanks, Bren! Trigo gave me a phonecall which stated just that. Apologies. I appreciate it.
    Member aspbite's Avatar
    St. Petersburg, FL
    I'm running a solid rear axle and getting ready to order my rear axles. What length studs are required for the pin drive adapters to work?
    Dec 2013
    I don't remember what the length needed is, but I do remember that they aren't manufactured by anyone. I checked everywhere. You have to cut them to length.
    Build Blog
