Results 1 to 5 of 5
Thread: Almost done with the wiring except,,,,,,,
    Groton MA
    Question Almost done with the wiring except,,,,,,,
    The donor is a 2004 WRX.
    My car starts & runs.
    All lights and directionals work except the 4 way flashers. Not sure why. (any ideas?)
    I have a few connectors that I can’t identify even after looking at the wiring diagrams and pictures in this forum.
    Need some help so that I can finish wiring and install the shift linkage so I can get to go cart.
    Connector 1 view A&B
    Connector 2 view A&B
    Connector 3 view A&B&C
    Connectors 4 view A&B
    Connector 1
    Connector 2
    Connector 3
    Connectors 4
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Flasher button is not the button on top of the steering console (if thats what you are trying to press)
    Groton MA
    Not the one on the top of the steering column, I finally figured that one out. This is the 4 way that that you push on then push off.
    Groton MA
    I have the 4 way flashers working. Now it is just trying to figure out if I can delete these connectors.
    Connector 3 looks like the plug labeled "Rear O2" in one of the posts but I have 2 sensors already plugged into the exhaust system.
    Are there 3 sensors?
