Results 1 to 7 of 7
Thread: Keeping OBD II
    Mar 2015
    Keeping OBD II
    Quick question and I am sure its been covered but my search hasn't really came up with much. will deleting non essential items From the wiring harness effect my ability use the OBD II port with Tuners such as the COBB Accessport. any input would be great
    Jan 2012
    No you will be fine. You can turn off most check engine lights that may occur.
    Harley818's Avatar
    Vancouver BC
    I've deleted many items/systems and mine works fine.
    Hooked up the Accessport 2 weeks ago, does the gauge functions, and I downloaded Stage 1 maps and it runs great.
    I haven't figured out yet how to do the CEL deletes.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
    Mar 2015
    to delete the CEL go on Cobb's website download a free copy of the Accessport Race( I Added a link ). after to get the program its pretty easy to figure it out through the menus on the top and you just un check the CEL's that you don't want.
    http://www.cobbtuning.com/Subaru-Acc...-p/atr-sub.htm
    Frankfort, IL
    remember that when you use the Accessport Race, you need to first open up the map you want to use (Stage 1 in Harley's case above) and then edit that map by unchecking the appropriate CEL's, save that revised map as something new, and then load that new map up to your ECU using the normal procedure.
    Harley818's Avatar
    Vancouver BC
    Hey great I'll give it a try.
    Harley
    south-central CT
    The only hangup is if you get a dyno tune you may end up locked out of that map. I don't know of any way around that. I have Accessport tune on my STi. I don't know if tuners are flexible about that issue or not. It was a little surprising for me to discover when I tried to access it.
