Results 1 to 3 of 3
Thread: Front wheel well aluminum
    Senior Member Quiny's Avatar
    Massachusetts
    Does anyone have some good pictures of the front wheel wells? In particular the panel that sits in front of the door. I have the windshield wiper option and it makes it difficult to install. I also don't understand the bends in those pieces they don't seem to make much sense. I have my body off right now but it looks like I will need it on to trim it properly.
    Mechie3's Avatar
    Indianapolis
    I have a few photos in my build thread. I had to trim the flat end of the fiberglass as it interfered.
    Zero Decibel Motorsports
    Check out my new website!
    Senior Member AZPete's Avatar
    I just put these splash panels on a couple of weeks ago because I wanted to get the door hinges all set first. Oh no, I didn't take pictures. Yes, mount your body and the doors first so you'll know where to trim. Fit the square end first so the lip is underneath the frame, snug it inward until flush and note the gap to the fender for the bulb seal. You want 1/2" - 3/4" for the bulb seal. Mine was short at the outer top so I added an aluminum piece so the bulb seal would seal tightly. I drilled all the holes but mounted these panels with just a few #8 screws for now because I'll want to remove them to reach the hinge bolts to install door cards and then the upcoming power windows.
