Fuel System Opinions
Hello,
I wanted to get some opinions of fuel system options. I purchased a fuel kit from a vendor and wanted to see if I could get some advice. The kit I purchased uses Socketless barb with AN fittings. (See picture attached). The fuel hose the vendor gave me is 350 PSI and is rated to carry fuel.(See Attached Picture) I do not have it all installed and before I do I still have a chance to change it.
Has anyone else used this type of setup? Is this robust enough.I know most folks run ridged tubing for the fuel lines.
Thanks for any advice you can provide.
Kevin
