Hi Tim
To solve the 18mm to 25mm thick rotor, I welded an old backing plate (1/4") to the backing plate of the outside pad.
Here are some of the trimming I had to do to make things fit .
Hi Tim
Bob, if the pad surface wears down to very little thickness, do you think it could come out of the calliper housing? or does your welded on piece act to keep it anchored?
That is exactly why I did it. With the pad material gone. It cannot come out of the bracket.
Also without this mod, the piston may come to far out of the caliper.
Below, you can see why I put it on the outside pad.
I wish the rotor as about an inch bigger in diameter.
