Results 1 to 5 of 5
Thread: Factory Five Roadster MK II For Sale
    Junior Member real2me's Avatar
    Mechanicsburg, Pa
    Factory Five Racing Mk II Roadster (FFR 5056) SOLD!!
    This is a quality build using only the best components. My goal was to build the car and maintain the look of the original, while implementing performance and reliability enhancements.
    This was a labor of love and was, in no way, rushed to completion (Yes, it’s a Mk II Roadster). The body work and paint were completed in February 2014 by Whitby’s in Greensboro, N.C.
    Everything works, and the car is a thrill and a pleasure to drive. If you are looking for a car that is fun to drive, reliable and great looking, this is one you should consider.
    Pennsylvania Titled, Registered. Pennsylvania Inspection completed on 5/27/16.
    Current mileage is just over 4500.
    I have saved every receipt for this build and will provide them to the new owner. I also have a build book that outlines details of the build that may be useful for future troubleshooting or upgrades.
    Paint Color:
    Guardsman Blue
    Wimbledon White Stripes
    Engine:
    5.0 Liter EFI (New / Non-donor)
    E-303 Cam Shaft
    GT-40P Heads
    GT-40 Intake
    70 mm Throttle Body
    1:6 Roller Rockers
    24 Lb Fuel Injectors
    Mass Air Flow meter adjusted for Throttle body and Injectors
    Ceramic Coated Ford Motor Sports Headers
    Factory Five Racing Catalytic Converters (Ceramic Coated by Jet Hot)
    Ceramic (Jet Hot) Coated Side Pipes
    Ceramic Coated Side Pipe Shields
    MSD Billet Distributor
    MSD Coil
    March Under -Drive Clear Coated Polished Pulley System
    Canton 8 Qt. Oil Pan
    Breeze Aluminum Radiator
    Taylor Racing ignition wires
    Cobra Polished Aluminum Valve Covers
    Edelbrock Polished Aluminum Water Pump
    BBK Adjustable Fuel Regulator and Gauge
    Energy Suspension Motor Mounts
    New Ford Racing Mini-starter
    Ford Racing 90 Degree Oil Filter Adapter
    Transmission:
    5 Speed T-5
    King Cobra Clutch and Pressure Plate
    Clutch Cable Adjuster
    Pro 5.0 Shifter
    3:55 Rear End Gears
    Interior:
    Classic Instruments Gauges (Electronic)
    Vintage Air Heater
    Honda S2000 Start Button
    Herbs Interior Door Panels
    Russ’s Garage Turn Signal System
    Finish Line Cobra Steering Wheel Center Cap
    Cobra Floor Mats (Finish Line)
    Mike’s E-Brake Trim Ring
    Factory Five Leather Seat Option
    Factory Five Tonneau Cover
    Wood and Leather Steering Wheels
    Mike’s Under Dash Panel
    Russ’s Throttle Pedal (With matching brake and clutch pedals)
    Cobra Earls extended passenger foot box
    Mike’s E-Brake handle cover
    Adjustable Driver’s Side Seat Track
    Steering & Suspension:
    Flaming River 15:1 Steering Rack
    Factory Five 3 Link Suspension
    Factory Five Tubular Lower Control Arms
    PS Engineering 15” Wheels
    BF Goodrich TA Radial tires
    Pro Shocks
    Miscellaneous:
    Windshield Wipers
    Heater
    Fary Five Hood Hinge
    Chrome Roll Bar
    Trunk Lid Support (Finish Line)
    FFMetal Battery Box
    Hella Horns
    Chrome Fire Extinguisher
    Finish Line Roll Bar Grommets
    Ford Motor Sports Aluminum Axle Girdle
    Flaming River Steering Rack
    Optima Red Top Battery
    Powder Coated Frame
    Tri-States Stainless Steel Brake Lines
    Polished Aluminum Side Louvers (Finish Line)
    Summit Brake Proportioning Valve
    Factory Five Wind Wings and Sun Visors
    Finish Line trunk lid support
    New Fuel Tank
    New Fuel Level Sender
    Chrome Windshield Mounted Rear View Mirrors
    Finish Line Polished Side Louvers
    Custom Polished Radiator Shroud that replicates the original
    New 427 style shifter and shifter knob
    Hidden trunk hinges (Breeze)
    New blue Weathershield car cover
    Price:
    $33,000
    Where are you located?
    Very interested in your car if you still have it. My cell is 828 699-3841, Doug in NC
    Please let me know.
    Beautiful car, price very well! It should go quickly. Good luck!
    Aug 2011
    San Jose, CA
    Has this car sold?
