So I can use it, but it sets the wheels out further by how much? Also will the brakes fit inside 15 inch wheels?
If you are going to use stock spindles instead of the FFR spindles order an SAI kit from Whitby's. That way you will have all the latest front end geometry.
Jeff,
Thanks, this was what I was trying to figure out. So I should use 94-95 spindles with 2002 rotors and calipers? All of this will work together? Also using manual rack, will there be any issues connecting it to the 94-95 spindles?
