I bought the Bear kit (I think) from Summit. For the R ride height you ditch the tie rod adaptor buy a 5/8 grade bolt, drill the steering arm for the bolt, use the tie rod adaptor, rod ends and shims to fine tune your bump steer. ( the R supplement will give you the bolt length 5" if I remember correctly and spacer I think it is 2 3/4)
