0
0
Blinker Wiring Help
I performed a wire diet on my 2002 wrx. The 2 turn signal wires are the light green and black and the black and green.
From the wiring diagram it appears the turn signal switch is connected to the indicator (gage connector) and the fuse box/relay. The wire leaves the fuse box/relay and is then spliced and travels to the turn signals.
My problem is that each of these wires enter the top and bottom of the fuse box/relay. My question is does the lead from the switch/gage connect to the top of the fuse box/relay or the bottom? Or does it matter as long the the switch is on one side and the lights on the other?
Thank you.
