Results 1 to 15 of 15
Thread: Wheel/tire sizes for the R
    Mar 2014
    Oakley, CA
    So FFR's 818R supplement recommends the following for wheel/tire sizes:
    Hoosier A7/R7:
    Front 225/40/17
    Rear 255/35/18
    Toyo R888
    Front 215/45/17 (This size requires the front lower arms be mounted for extra caster)
    Rear 255/35/18
    Yokohama Advan Radial Slicks
    Front 210/610/17
    Rear 240/640/18
    From what I can tell, FFR's gray 818R show car does indeed have 18s on the rear. However, after some searching on the build threads, I see Chad and SixStarCars running 17s on the rear. Plus, Chad went to 235s on the front, and SixStar squeezed 245s on the front.
    For a guy who has never bought slicks, what do I need to be thinking about before shelling out money for wheels? Any pros/cons to 18s in the rear vs 17s? I know Chad has talked about rubbing issues on the fenders. Do the 235s/245s really work?
    Mar 2014
    Oakley, CA
    Dumb question? I just wonder why FFR recommends 18-inch rears but none of the guys who actually race seem to be going that route. Just cosmetics?
    Feb 2014
    Asheville, NC
    For me it was money and clearance. I could get a 17x9 with a good offset. The advantage to going 18" was a 9.5" wheel but in the offsets available (within financial reason) I couldn't make the wheels fit. Might as well stick at 17" diameter at that point.
    Bowling Green, KY
    I have gone with 17X8 on the fronts and 18X9.5 rear. At this point since I have the wheels I am not going to second guess myself and I have a number of tire choices available for the 17 and 18" wheels.
    Clovis, Ca
    17" tires/wheels are generally cheaper/lighter. With any quality race wheel, you are not stuck to off the shelf offsets. I was able to get a 17x9 rim in whatever offset I pretty much wanted with a very reasonable price.
    225 R7's will rub on the front. Sure, you can maximize the camber as a band aid like FFR wants us to do, but the magic camber number for me requires rubbing. FFR knows this, that's why they redesigned the front fenders to have more "Flare" like the rear flare.
    Thanks- Chad
    Senior Member xxguitarist's Avatar
    Just another option for you guys, we have 245/15 A7s front. They are lower offset than needed, but it was what was available. They rub slightly on the inside of the fender, but it's functional. Rears are currently 16s (245), will be 17s (295?).
    -Andrew
    Building 818S/R #297 with Tamra
    08 Mazdaspeed3 | '12 F800R | '97 Miata
    Mar 2014
    Oakley, CA
    Dragging this thread back out to douse it with a little gasoline:
    How important are forged wheels for racing? Is it worth the 4x-5x price premium?
    It seems for almost every non-forged wheel out there, you can find someone claiming that they've seen 100 of them fail in person (exaggerating slightly, but that's what happens on the internet). I know several of us R builders are running cast wheels. Is the spun-barrel process advertised by Enkei and several others a significant improvement over cast?
    Clovis, Ca
    Quote Originally Posted by Zach34 View Post
    Just grab some Team Dynamics 1.2's. Forged are not worth the extra cost for the 818. I just had a Corvette blow up a Forgestar wheel in front of me at the Western NASA Championships.
    We have cast OZ racing wheels on all the NP01s. They bend when we abuse them, but are easily fixed by a good wheel shop. None have broke. The repair shop says it all comes down to the pot metal. The cheap Chinese pot metal in some wheels are the reason of the failures. Stay away from those cheap Chinese wheels for racing, and you will be fine.
    Thanks- Chad
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    Many people are racing with cast aluminum wheels. Enkei have proven to be strong, light, and reliable, especially the RPF1. There are cheaper wheels out there like Rotas. You will hear horror stories about them but plenty of people race on them now, and TONS of people race on Enkeis and don't break them.
    I wouldn't buy a forged wheel for strength since it's really not needed vs a well-made cast wheel. I would buy a forged wheel for weight savings. As for whether it is worth the price premium, that's not something I can say because it depends on the value of the dollar to you and how important it is to have lighter wheels. The lighter your wheels and suspension (un-sprung weight), the better your car will perform and handle.
    Jun 2015
    We tried 235 hoosier slicks on the front with 35mm offset wheels. Doesn't work well if you want the ride height less than 3.5" and spring rates less than 650lbs. We are going to 15's in the front, with 245 slicks. That will give us what we need to lower the car to where we want it.
    We have run some pretty cheap wheels with slicks without issue, while at the same time, breaking a panasport on the same car. We don't go for thin spoked wheels though, and we inspect often.
    Mar 2014
    Oakley, CA
    Thanks guys, that's perfect.
    Cutting through the marketing lingo is part of the challenge. I looked at Forgestar. I don't think any of their wheels are actually forged. They are cast and the barrels are roll formed, which is fine (OZ and Enkei do the same with some of their wheels and it sounds like those are winners), but it's confusing at a glance. They are just throwing the word "forged" into their roll-forming process since it sort of mimics actual forging.
    That's good to hear about OZ and Enkei, those are two I've been looking at. So many of their wheels are 18"+, though. Any opinions on SSR?
    I do have the new nose - hopefully that lets me get the car low without rubbing too much on 17s.
    Sgt.Gator's Avatar
    Bend, Oregon
    I've used Enkei PF01 and RPF1 and not had any issues. I *think* all Enkei Racing wheels are made in Japan. I'm not sure about their Tuner wheels.
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Enkei is a Japanese company, but is all over the world. There is a big plant near one of our autocross sights in Columbus, Indiana. Making wheels there for 30 years.
    http://therepublicphotos.com/p133247...9007#h6a9a9007
    Reno, NV
    Here is a video that shows how flow formed wheels are made. The wheel "blank" is cast then the rim part is forged to the finished width.
    http://949racing.com/wheeltech.aspx
    Links not working right now. Here is the same video on YouTube.
    https://www.youtube.com/watch?v=nG0cwYIbsNc
    818R Build date 10/31/15
    Sgt.Gator's Avatar
    Bend, Oregon
    I had no idea! Thanks.
    818R ICSCC SPM
