Sounds like you have the sender or sender's wired wrong they should measure about 10 ohms(FULL) to <100 ohms (empty). Subaru gas tank has two senders wired
in series, each one is about 5 to 50 ohms. If you are using one sender you must get a 0 to 100 or (0-90 ohm)ohms fuel sender.
