Results 1 to 3 of 3
Thread: heater vent ducts
    Calgary, Canada
    heater vent ducts
    How on earth do you fit the heater hose over the screen vent duct? There's two barbs that retain the hose, I get that. And it works for the round connections on the heater, but do you think I can get them on, and stay on? It's getting to the point where I may not install screen demisters. If the damn thing came disconnected when the car is finished there's no easy way to reconnect!
    Chop'annoyed'thebass
    Calgary, Canada
    I've decided the supplied vent ducts/boots are unusable. There must be someone here that's run into the same problem? What did you do to solve?
    Senior Member Norm B's Avatar
    I used the supplied defrost ducts but had to modify them to work. The passenger side was extensively modified to fit around the glove box. On the drivers side I modified it by heating the hose attach end with a heat gun and flaring the end slightly. To keep the hose attached I used a zip tie above the flare.
    Norm
