Results 1 to 5 of 5
Thread: Best AC and PS unit for the coyote engine
    Member Paquette173's Avatar
    Hello, these are my last 2 parts missing of the puzzle.
    I will be ordering my engine with mike forte.
    He is offering me AC and powersteering. The AC is one unit and i need to order another from FFR for the heater. I also saw whitbymotorscars 2 in 1 AC and heating. I'm looking for a clean look Under the Hood and hidden vents. Witch one would be better ?
    2bking's Avatar
    Garland, Texas
    I have the Whitby unit. It pulls air from inside the car for both AC and heat which I think is better than using outside air from under the hood. If the air comes from under the hood, during the summer when the fan is off hot engine air comes through the vents. The vents are below the dash albeit not hidden except somewhat out of sight. It also has defrost capability. It fits with the Coyote engine but the lines have to be dressed close to the housing. Whitby's was getting the core from Vintage Air but Vintage Air quit making them leaving Whitby to find another source. You might want to contact Whitby to see if the units are still available.
    King
    I used the electric power steering option and the stock Ford compressor with lines I made up from 2013 Mustang hose assemblies. I have more DSCN0614.JPGFord Coyote Fittings modified.JPGphotos if you need, my build is a 33 HR with the 5.0 Coyote.
    Don
    Sorry I forgot a post of the power steering module.
    Senior Member DaleG's Avatar
    Mar 2013
    A bit pricey, but this set-up works well; all you need to add is the AC/Heater (I used the one mentioned above from Whitby...the Vintage Air): http://www.vintageair.com/cyotfrntrnnr.asp
    As for the unit itself, maybe the Compact design in this link?: http://www.vintageair.com/2015%20Cat...talog%2010.pdf
