I can't help with the CMCV and it looks like the port I used for the pressure regulator isn't visible or isn't there in your pictures. Mine is a vertical plastic tube/port on the rear left end of the intake manifold. It's the same port that the FFR instructions show for attaching the pressure regulator vacuum hose. But the port comes blocked on the earlier engines and needed to be drilled out to get vacuum.
As for the PCV port in the intake, I made a part and installed it in the 4" curved Spectre tube. It turned out to be a simple fix and looks like it belongs. A few pictures are of the part and completed assembly. 2014-549d.jpg2014-548d.jpg2014-547d.jpg2014-546d.jpg
I used this piece from Mr 2bking and it worked perfectly!! Would highly recommend.
Chuck Krueger
MK4 Kit - Picked up 4/5/14, Complete Kit, 3-Link, Wilwood upgrade, Coyote, TKO 500, First Start 7/25/15
2000 C5
2003 C5 Z06
2007 C5 Z06
