Results 1 to 12 of 12
Thread: Manual vs. power rack
    Nov 2015
    Just looking for some opinions on manual vs power, my project has a power rack but as light as the car should be is it needed? Seems like overkill. It currently has 245s on the front with a '03 cobra knock off wheels but it will most likely end up with the halibrand copy's and DOT stickies😄
    Trick Tool Maker, Super Moderator Hankl's Avatar
    Northern CA
    Power, you can alway use a reduction valve.
    Hank
    “If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    For a street car w/ narrow tires you can probably get away w/ the slow manual rack. But, to make your car drive more like a modern car, go w/ a 3.0 turns power rack. You will be glad you did. There have been maybe two people who went power to manual and 100s who went manual to power.
    Nov 2015
    that makes good sense, thanks we will proceed acordingly!
    I always point this out (and likely some are tired of hearing it...) every time the manual vs. power steering discussion comes up: Don't think of it as just about steering effort. That seems to be what most focus on. But power steering also allows you to significantly increase the caster angle of your front spindles, providing better stability and centering while driving down the road. The manual setup drives good, the power setup drives better. I've had both, and won't be going back to manual.
    I have 265-35-18's on the front with Avon auto-cross tires. I've actually bent the steering wheel trying
    to turn the car..... The last time I worked on the car (several years ago), I was in the process of converting
    it to power steering. Unless you like driving a truck, go with a power rack...
    FFR4784CP - The first coupe with a "Falk'n Bubble"
    http://www.replicapromotions.com
    Saleen - Power in the hands of a fool!
    First build was manual. Second is power.
    I'll be switching the 1st to power this winter. It just makes for an easier driving car.
    Nov 2015
    thanks guys, advice is always the best teacher! i'm not a fan of the pump and bracket but the driveability will certianly outweigh the cosmetic issues!
    Senior Member Gbeck's Avatar
    Jan 2013
    South central PA
    You might consider the Unisteer electric power steering unit. I'm considering it in my build. Kinda pricey though.
    I found in another post that Mike Fortes handles it.
    http://www.unisteer.com/electric-pow...-steering.html
    Senior Member HCP 65 COUPE's Avatar
    NORTH CENTRAL CT
    You could also run fast Freddies electric hydraulic here's a link.
    There is quite a few people around here running this setup.
    http://www.fastfreddiesfabrications....p?id_product=4
    Nov 2015
    That is a good looking set up but for that $ I'd rather have an alum. flywheel and a set of sticky tires to take out to Hallet!
    And don't forget that to fill those coupe wheel wheels you can run 315 front and 335 rears so those 315s really increase the needed effort.
