0
0
Originally Posted by
myjones
I do plan to use better side mirrors, the 818 coupe at SEMA had some nice mirrors on the doors that I will probably use.
The inside mirror should work better on mine because of the location not being on the dash. I have the ideal mount for it right up against the hardtop on the rollbar.
Since I'm not tall my line of sight should be good out the back window and I think the segmented mirror will actually let me see out both side windows somewhat.
Those are actually the same side mirrors we used on both the hot rod and the 818.
We mounted the rear view mirror to the roof rather than the dash and you can see all there is to see out the back window. You may be right though about being able to see out the side windows a bit, which would help. With the segmented mirror, you may be able to essentially just use the middle and 2 outer mirrors and ignore the in between segments.
