Thanks Thanks:  8
Likes Likes:  44
Results 1 to 40 of 320
Thread: RR20AC Build Thread
Threaded View
  1. #11
    RR20AC's Avatar
    Puyallup/WA
    20th Anniversary build- dash mount
    The top mount works fantastic with a brass rod to pull, letting go 16 attach points that hold it on. I used the breeze lower brackets that I had powder coated. Made up a center console for my wilwood bias adjuster, electric steering adjuster, usb and 12 volt outlet. The cover is hinged and is made of stainless. I also received my shifter boot and it is setting there also. I think a few more switches mounted on the dash and the RT steering unit mounted and I can then start the final wiring.
    20th Anniversary MK4 Roadster, #8752, 18 of 20, Delivered 12/03/15, 1st Start 01/28/2017, off to paint 4/13/2017, Forte 351w/ Holley EFI, Forte throttle linkage, TKO 600/Forte Hyd. Clutch, UniSteer Electra Steering, RT's turn Signals, many Breeze parts, Paint by the Jeff Miller. Finished on 10/08/2017. 500 mile inspection on 10/21/2017, 3000 mile inspection on 1/14/19.
