Page 1 of 4 123 ... LastLast
Results 1 to 40 of 128
Thread: Zero Decibel Motorsports, Coupe Style Hood Hinge
    Mechie3's Avatar
    What: Group buy for hood hinges that swing the hood forward and allow you to eliminate the front hood pins. This version is the version compatible with the coupe front end. It also will work for the S/R original front end if you desire to add a mesh grille and need clearance over the top of the grill. The Coupe style arm is much more swept back to provide the clearance and, as it requires 2x the material it also costs 2x as much for the single piece.
    Individuals wishing to upgrade their S/R front end to the coupe front end only need to purchase the arm. All of the existing S/R hinge parts are compatible with the coupe hinge.
    Coupe Arm:
    Cost:
    Full Hinge Setup:
    5-9 people: $240
    10-14 people: $225
    15+ people: $210
    Coupe Arm Only (for S/R retrofits)
    5-9 people: $70
    10-14 people: $59
    15+ people: $56
    To make it financially easier for existing customers to retrofit, prices for these pieces is only $10 over my actual cost. Mr. wonderful on Shark Tank would call me stupid. Good thing I don't like Mr. Wonderful.
    What You Get:
    Two hinge bases (laser cut, bent, TIG welded)
    Two hinge arms (laser cut)
    Two hood brackets (laser cut, bent, TIG welded)
    Hood Brace (laser cut, bent)
    Rivnuts for frame mounting
    Bondable studs for hood mounting
    All stainless hardware
    Group buy will stay a couple of weeks depending on volume of response. 50% deposit due at the end of group buy. Lead time on parts is roughly 2 weeks after the group buy closes.
    Original development and test installs of the S/R style shown here.
    Matteos install can be seen here:
    http://thefactoryfiveforum.com/showt...l=1#post202454
    Dan's install can be seen here:
    http://thefactoryfiveforum.com/showt...l=1#post202558
    1. Kurk818
    2. 07FireBlade
    3. TX Lou
    4: STiPWRD
    5: Redfogo
    6: Frank818
    7: Metros (arms only)
    8: Joseph
    9: SnyderJD
    10: AZPete (arms only)
    11: NB in SD (arms only)
    12: cmcintyre
    13: 508 WRX (arms only)
    14: Newkitguy
    15: Phillig
    16: FFR ADV
    17: 65 Cobra Dude (arms only)
    18: Rori
    19: PSUalum1986
    20: Slatt
    21: BN
    22: vrumpsh
    Puyallup, WA
    Count me in for a Coupe set
    Jan 2012
    Coupe set for me. Where you able to prototype the glass hinges for the coupe also? I have seen them yet they might be the stock hinge setup just moved.
    Mechie3's Avatar
    It's on the list of things to do. Not 100% sure what it is since the manual has no updates for the coupe yet. I have seen the same trunk bracket in the coupe kit so it might be similar.
    Senior Member TX-Lou's Avatar
    Count me in for a Coupe set for me as well.
    Leesburg, VA
    In for the full setup!
    I was in the original group buy list for the C am I good on that list or do I need to be added onto this list?
    Mechie3's Avatar
    I'm making a new list just in case people on the original one want out. I'll add you to this one.
    I think you shouldn't call it "coupe", as all the 818s now use this front nose. Reading the subject non-coupe people may think it's not for them, but it is.
    I was part of the old group buy for hood hinges, does it mean we start all over or only for the arms?
    Count me in no matter your choice.
    Senior Member metros's Avatar
    NoVA
    ^arms only.
    Sign me up to upgrade my arms for the new front end.
    Tallahassee, Florida
    I am on the old list, bring my name forward to the new list for the Coupe hood hinge. Thanks
    Mechie3's Avatar
    I'm counting anyone who wants a full set or just arms towards the total as the biggest expense is the arms. In my pricing spreadsheet I have the costs for all of the non-arm parts set at the 30pc purchase price (which was the original group buy). The only thing affecting the group buy price this time is the cost of the arms.
    Senior Member SnyderJD's Avatar
    Sign me up for a full setup.
    Mechie3's Avatar
    One more person and the price drops $15.
    Senior Member AZPete's Avatar
    Craig, I need just the new arm for the new front since I already have your hood hinge. Hopefully this is the one more you need but if you need a full hinge order . . . guys, this hinge is really needed and it is beautiful.
    AZPete
    Senior Member NBinSD's Avatar
    Sep 2014
    In for just Arms too.
    Mechie3's Avatar
    AZPete
    It counts. I already ordered most of the other parts the last time around in anticipation of another go around of orders.
    Four more and we reach the last level.
    Senior Member cmcintyre's Avatar
    Danbury, CT
    I'll take a full set. Roof and bumper pickup at Moochfest.
    " That which is rightly done, however humble, is noble." Sir Henry Royce
    SN 46 In the building 10/4/13.
    Go Cart 10/20/16
    Coupe Conversion
    EJ205 Wagon donor
    Member 508wrx's Avatar
    Nov 2012
    Taunton, Ma
    I'm in for a set of Arms
    "aerodynamics is for people who can't build engines" - some old dude
    "Shut up! I know what I'm doing" - some angry finn
    Senior Member Zodiac's Avatar
    Jun 2012
    Southern California
    do you still have ones for the old S model? that's what I need since I haven't been seeing them on your website :P
    Mechie3's Avatar
    I do. They're $190 + shipping. In stock right now. I've been too busy to update my site. doh!
    Apr 2014
    Yeah you can add me to the list
    Mechie3's Avatar
    Got it. One more and we drop to the last bracket and I'll just go ahead and order parts.
    Waldorf, MD
    Count me in for a full coupe setup.
    Senior Member FFR-ADV's Avatar
    NH
    Craig,
    Please count me in for the full coupe hinge setup. Thank you for doing this!
    Port Charlotte, FL
    Craig, I'll take a set of the upgrade arms.
    Thx,
    Henry
    Mechie3's Avatar
    I'll keep this open for a couple more days then start taking deposits to place the order.
    rori's Avatar
    Tulsa, OK
    I'll take a full set for the coupe.
    Westminster MD
    Count me in on one full set for the Coupe
    Member Slatt's Avatar
    Anchorage, AK
    A full set for the coupe, please.
    BN's Avatar
    Sept-lies Qc.Canada +FL. Danvenport
    I'm in full set the coupe, please ben
    Jan 2012
    Let me know when you need some money.
    Apr 2014
    No deeper discount after 20? Lol
    Mechie3's Avatar
    No. 40 pieces (which is 20 kits) is about the point of diminishing returns for amortizing the setup fees. 30 Pieces (15 sets) was only about $1 more per piece compared to 40 pieces.
    Mechie3's Avatar
    I'm open for deposits at this point. Deposit is 50% of the total (not counting shipping). For the arms only this is $28, for those ordering a full setup it is $105. my paypal is [email protected] When you send payment please include your forum name and a note to verify it's for the arms or the full setup. I'll be placing the order for parts this coming week. It will take a couple weeks after that for part delivery, bending, welding, and assembly. Arms can be sent out quickly (they only require deburring and sanding).
    I've got a little something planned too. Details to come.
    Puyallup, WA
    Deposit sent..
    Westminster MD
    For those of us without a PayPal account, how do you want us to pay the deposit? PM if you wish.
    NoVA
    Deposit sent 2nded
    Sep 2014
    Deposit plus pmt for other goodies sent. Thanks Craig!
    BN's Avatar
    Deposit send
