Results 1 to 1 of 1
Thread: Header Tank Kit
    San Diego
    Header Tank Kit
    Well, the parts are in, I processed them last night, the instructions are done, and I have five Header Tank Kits currently in stock. They can be seen and purchased here:
    http://myraceshop.com/GTM-R_Pieces.html
    Sorry this took so long, but I think this will be an easy kit to install. Here's a pic of how it should go together from the instructions:
    I'd also like to note that not only did the parts come in for the Header Tank Kits, but www.myraceshop.com also has a couple more Heater Bypass Valve Kits, Power Steering Controllers, Alignment Shim Kits, and 930 Outer CV Axle Conversion Kits in stock.
    I also got the makings for the 935 CV joint setup last night, so THAT is under way also. If money is not a concern, but strength to hold over 1000 horsepower...with slicks!...is, then www.myraceshop.com has the driveline parts for you!
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
