Retro,We are using over hung, reverse mount, not fire wall mount as the tube frame is stronger than the firewall. It's also easy to adjust and plumb the balance bar. IMG_0535.JPG
Way lighter, but some welding required. undo the lines, pull 4 bolts and the complete assemble comes out the top, which is great for changing master sizes.
What pedal set are you using?
818R Build date 10/31/15
