Stahlbus Oil Drain Valves
Stahlbus oil drain valves are installed in place of conventional oil drain plugs. Once installed the valves simplify the procedure for changing oil in your car. The quick disconnect drain hose connector snaps into place opening the valve to drain the oil. When the drain hose connector is removed the valve automatically closes. Each Stahlbus oil drain valve includes a high-strength steel valve body, copper sealing washer, anodized aluminum safety cap, quick disconnect hose connector, 40 cm Silicone drain hose, and instructions. The oil drain valve is available in several thread sizes.
https://www.reverselogic.us/shop.htm...ves/p/53219933
https://www.reverselogic.us/stahlbus.html
