Hey Gang,
Please share your opinions about Carburetor choices for my MK-4 Roadster.
My engine is about to come back from my builder this Saturday and I was planning on buying an Edelbrock AVS 800.
The Engine Guru suggested a Quick Fuel 780 or Holley 770 with vacuum secondaries to keep things simple.
He stated that he likes the Holley style carbs since he's been playing with them for a tad over 50 years.
The engine should put out about 440-460 HP and about the same number for torque.
NOTE: Please don't cringe when you see what's going between the frame rails.
383 Small Block Chevy 9.7-1 Pump Gas Friendly Compression Ratio!
Engine Operation Range >>> 2,300 – 6,500 RPM.
Eagle Internally Balanced Rotating Assembly With 6" H-Beam Rods With Floating Forged Flat Tops.
Dart Iron Eagle 215 CC Heads with 2.05 Intake & 1.60 Exhaust Valves.
Weiand Team-G #7530 Single Plane Manifold.
Harland Sharp Roller Rockers & Other Go Fast Goodies.
Comp Cam Extreme Energy 284 Hydraulic Flat Tappet Cam.
Schoenfeld IMCA 1 5/8” Modified Headers / 3.0” Collector Into Traditional Factory Five Stainless Side Pipes.
New Old Stock Corvette ZF 6-Speed Transmission With Hydraulic Clutch. (.75 5th & .50 6th Gear Over Drives)
Moser TSD 500 / 3.73 Ratio / Eaton Style Sure Track Posi.
Please know that your opinions will be very much appreciated.
Steve >>> aka: GoDadGo
