Most oem systems report 85% as maximum. In other words, the ecm will use 85% as wot. Its all relative. Not sure about steady 0% at idle end. Use ohmmeter
and check resistance of tps sensor from the slider to one side. It should be a smooth transistion. An analog meter can see jumps showing errors better.
