Results 1 to 14 of 14
Thread: Quiet down!
    Carrollton, Ga.
    Quiet down!
    I am beginning to accept the fact that I will have to have some type of noise reduction plan to run on certain tracks in my area. Having searched these pages, there are a number of good discussions. However, most discussions focus on the tactic of changing the side pipe exit so that the noise is directed downward, but I don't think that will suffice for all situations.
    I presume that the Challenge car side pipes are without any form of internal muffling. However, the standard roadster side pipes should, including the optional stainless ones - basically a glass-pack style straight through design, of course.
    Does anyone know:
    1. what the db reading of a standard, unmuffled Challenge car side pipe is at WOT?
    2. what performance reduction the muffled FFR side pipes cause?
    Bill
    ttt for the racers out there...
    Apex, NC
    Believe it or not, I have yet to be dinged, and this included Road Atlanta.
    It will say it was much quieter before the headers. The OEM headers actually reduce quite a bit of noise with out a huge penalty in flow.
    2012 NASA-SE FFR Champion
    2011 NASA-SE FFR Champion
    Race page - http://www.mh-motorsports.com/race.shtml
    Team Facebook page - http://www.facebook.com/pages/MH-Mot...s/264814350042
    Mark Dougherty's Avatar
    Hershey PA
    challenge cars use the stock ffr side pipes
    The traveling Builder
    717-773-5624
    Hershey PA
    many things determine DB readings
    lower compression gives lower readings
    vice versa
    717-773-5624
    Carrollton, Ga.
    That's good news, Marty. I'll have to say, some of the cars that run at Road Atlanta are ear-splitting, so I'll bet I'll be OK there. I am also a member of a club track (Atlanta Motorsports Park), where db restrictions are in the 90s. Our club has neighbors, so I'm thinking the noise rules will be enforced.
    I just took delivery of my BBK equal length headers.....
    Mark - are the stock pipes then muffled like glass-packs?
    Thanks, guys.
    wallace18's Avatar
    Trenton, Florida
    If you need a set of stock side pipes I have a brand new set in the box. PM me if interested. I'll make you a deal on them.
    Maricopa AZ
    What you will end up with is probably 2 sets of pipes. One with a very quiet muffler and the other stock or open. The other option is make the side pipe a slip on and have a few different inserts for different tracks with noise restrictions.
    I've used the Dynatech Cone Inserts in a 3" diameter, 20" long collector on another car.
    It took the edge off the open header exhaust note; however, I cannot tell you how much it helped or hurt the overall performance because the car was never run on a dyno.
    Overall E.T.'s stayed the same with a loss of 1 or 2 MPH on the big end, but improved on 60' times a tenth or two with the 1/8 mile MPH being virtually unchanged.
    383 SBC / 1980 Camaro Z-28 / 3,600 Pound Car / 3.73 Ring & Pinion Ratio
    Carrollton, Ga.
    Thanks, Gordon. But clarify something for me. I am under the impression that the stock side pipe is muffled with a glass pack - type configuration (i.e., with 'glass packing along the walls of the side pipe held in place by a slotted metal shroud). Is that true? If so, what would you do to create more muffling? Or do the stock ones have a less effective type of muffling?
    edit: I just read on the FFR Web site that the stainless side pipes are glass-packed; what about the regular, mild steel ones?
    edit: And thanks, GoDadGo; your post pooped up the instant I responded to Gordon. That's very useful information; thanks
    Hershey PA
    yes
    the stock pipes are a large glass pack
    there is a thread on the forum about a much quieter glass pack to replace the FFR unit
    if you need someone to weld them in for you let me know
    we can mock them up on a car and do it for you
    717-773-5624
    Carrollton, Ga.
    OK; thanks, Mark. I'll see how the stock ones do and go from there.
    Bill
    Joliet, IL
    Don't forget to read the rules or check with a series director.
    Our cars are pretty low/deep toned(?) compared to a straight pipe rotary (OMG, jab a pen in my ear to make the noise stop!). Most of us have not had a problem but I know it can be a track/regime specific problem.
    FFR Spec Racer
    Carrollton, Ga.
    avgjoe - I'm sure you're right. I want to be able to at least show a good-faith effort at rules compliance, especially with my club track and its neighbors. I also agree with you about the rotaries! Absolutely piercing.
