Is there a reliable way to test the switch? Immersion in hearing water with continuity meter attached? Mine never has acted right and fan never came on right (I wired manual switch in when I built as a backup) and I want to fix it when I rebuild the motor this month. I'm thinking I need a lower temp one maybe (like linked above) and pipe dope instead of tape (Yeah I should have known better). It worked when I first setup but hasn't since.
