How well does the 185 deg switch work. I have avoided it because, since it turns off at 165-170, I thought it would always be on after the first fan start. Figuring the engine will never get to 165-170 w/ a 180 deg t-stat.
Can't answer that just yet. After installing the sensor most of my time was spent in the driveway with a few trips around the block. Once the temp was up and it was cycling on and off I put it back in the garage. I'll be out this weekend and get a better handle on how it works.
-Fred
