Results 1 to 6 of 6
Thread: Murray Turbo Seal Clamps and Dual Bead Clamps
    Sgt.Gator's Avatar
    Bend, Oregon
    Colonel Red Racing is now a Murray Clamps Authorized Reseller.
    Murray Constant Tension Turbo Seal Clamps – With a convoluted heat-treated band that provides spring-like tensioning effects for thermal cycling hose applications.
    Murray hose clamps are designed to compensate for the effects of heating and cooling, and the compression set of the hose. Murray's convoluted spring-action outer band is the solution.
    Murray’s unique “DUAL BEAD SHIELD” concentrates band-sealing pressure, increasing performance up to 30% compared to standard smooth liners. Flanged edges protect soft hose compounds from abrasion and wear.
    The unique Dual Bead Shield provides superior sealing pressure via its two raised ribs and flanged edges to eliminate damage to the hose when tightened.The unique inner liner also concentrates band-sealing pressure, increasing performance up to 30% compared to standard smooth liners. Flanged edges protect soft hose compounds.
    Murray Constant Tension Turbo Seal Clamps evenly distribute the clamping force completely around the piping makes them superior to t-bolt or regular worm clamps. These clamps are excellent for turbo boost applications.
    Electropolishing improves weld strength, which leads to improved performance, improved corrosion resistance, and enhances appearance with a more even finish.
    This clamp is used in automotive, off-highway, agriculture, heavy duty, aircraft (non-flight critical applications only), and military industries and can be found on turbo chargers, tanks, air-to-air, cooling and fuel lines.
    Murray Clamps are widely used in WRC Racing around the world. See the clamps in the image of the 2016 Subaru Isle of Man WRX race car that set the lap record!
    Unlike T-Bolt Clamps that have a very limited range, these Turbo Seal Clamps fit over a wider range of hose sizes.
    Turbo-Seal Material Specifications
    Band Material: Special proprietary grade of stainless with excellent spring properties
    Housing Material: 300 Series Stainless
    Shield Material: 300 Series Stainless
    Screw Material: 300 Series Stainless
    Rated Ultimate Torque: 75in.lbs. min. (8.5Nm)
    Recommended Installation Torque: 50in.lbs. (5.6Nm)
    Turbo-Seal tension clamps are offered in several sizes.
    Part Inches MM Price
    TSS16S30EP 1-1/5" to 1-5/8" 30mm to 41mm $9.25
    TSS20S30EP 1 3/8" to 1 7/8" 35mm to 48mm $9.27
    TSS28S30EP 1 5/8" to 2 3/8" 41mm to 60mm $9.58
    TSS32S30EP 1-13/16" to 2-5/8" 46mm to 67mm $9.85
    TSS36S30EP 1 31/32" to 2 7/8" 50mm to 73mm $10.03
    TSS44S30EP 2 1/2" to 3 3/8" 64mm to 86mm $11.04
    TSS48S30EP 2 3/4" to 3 5/8" 70mm to 92mm $11.59
    Factory Five Forum members take 10% off your total price. This is for Factory Five Forum Members only! Shoot me a PM to purchase. There is a $3.50 shipping charge that applies only to the first clamp, all additional clamps are free shipping.
    OR, you can buy them on my ebay Store here: https://www.ebay.com/str/colonelredracing
    However the Ebay store won't be the best pricing for large orders because I can't build in the FF Forum 10% discount or the best shipping deal.
    Murray Dual Band Clamps:
    Basically the same clamp minus the spring. Great for cooling lines and anywhere you would use a standard worm clamp, only better!
    DB20SS 11/16" to 1 5/" 17.5mm to 41mm $3.64
    DB28SS 1 3/16" to 2 1/8" 31mm to 54mm $3.79
    DB36SS 1 11/16" to 2 5/8" 42mm to 663mm $3.98
    DB44SS 2 3/16" to 3 1/8" 56mm to 79mm $4.25
    DB48SS 2 7/16" to 3 3/8" 62mm to 85mm $4.41
    DB56SS 2-15/16" to 3-7/8" 74.6mm to 98.9mm
    DB64SS 3 7/16" to 4 3/8" 88mm to 111mm $4.67
    DB72SS 3 15/16" to 4 7/8" 100mm to 123mm 4.72
    Tech Tips From Colonel Red Racing:
    Silicone Hose Outer Diameter Sizing:
    Use this chart to determine which Murray clamp to use on your silicone turbo hose connections. For example a 2 1/2" intercooler pipe uses a 2 1/2" silicone ID connector, but since the silicone outer diameter is larger you need a larger than 2 1/2" clamp. Silicone hoses are NOT all the same thickness so you can measure the outer circumference of yours and look it up on the chart to be sure you get the right size.
    1.75” Hose=44mmID=2.07”OD=53mmOD=6.5” Circumference=166mm Circumference.
    2.0” Hose=51mmID=2.32”OD=59mmOD=7.29” Circumference=185mm Circumference
    2.25” Hose=57mmID=2.57”OD=66mmOD=8.07” Circumference=207mm Circumference
    2.50” Hose=63.5mmID= 2.82”OD=72mmOD=8.85” Circumference=226mm Circumference
    2.75” Hose=70mm ID=3.07”OD=78mmOD=9.65” Circumference=245mm Circumference
    3.0” Hose=76mmID=3.32”OD=85mmOD=10.43” Circumference=267mm Circumference
    3.13” Hose=80mmID=3.45”OD=88MMOD=10.84” Circumference=276mm Circumference
    3.25” Hose=83mmID=3.57”OD=91mmOD=11.22” Circumference=286mm Circumference
    Intercooler Piping Tech Tips
    The Constant Tension clamps are good for Intercooler piping and the CAI inlet on the turbo. The Dual Bead clamps work great on typical coolant hoses and other applications where the temps move slower and are more stable.
    Be aware, if your intercooler pipes have oily residue in them and inside the silicon coupler you have to clean them really well, to make sure oil is gone. No clamp will hold an oily IC pipe under boost.
    And after cleaning off the oil a quick spray of Aqua Net Extra Hold hairspray does an amazing job. Spray the outside of the IC or Intake piping with Aqua Net Extrra Hold, then slip the clean silicone hose coupler over it. You have a few minutes to adjust the pipes before the AquaNet sets up. Since we started using the constant tension clamps + Aqua Net Extra Hold we've never popped off a IC pipe in our races.
    Colonel Red Racing
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Sgt.Gator's Avatar
    Bend, Oregon
    818R ICSCC SPM
    Sgt.Gator's Avatar
    Bend, Oregon
    2017 STI 24 Hour Nurburgring Racer
    The 2017 STI 24 Hour Nurburgring Racer.
    818R ICSCC SPM
    Sgt.Gator's Avatar
    Bend, Oregon
    Fascinating Tech Talk on a STI at the pinnacle of development. Note the Murray Constant Tension Turbo Seal clamps, we sell them on our eBay page.
    Subaru WRX STI RA Tech Talk.
    818R ICSCC SPM
    Sgt.Gator's Avatar
    Bend, Oregon
    I attended the Pirelli World Challenge at PIR. Here's something I never thought I'd see, five Subaru Pro Road Race Cars at the same place and time! And then they won 1-2 in the TCA class. Nice work TechSport Racing!!
    Shralp tries on one for his competition test fit:
    They were running 1:27-and 1:28 best laps. Pretty close to stock. Intake, exhaust, oil cooler...you can buy one here: http://techsportracing.com/product-c...ubaru-brz-tca/
    The Hyundai TCR class cars were pretty cool and very fast! They are way more developed than the TCA class cars like the above BRZs. Both classes run in the same race but the Hyundai cars lapped the first place TCA BRZ three times in one hour.
    And moving around to the front what do I see on the intercooler piping? Murray Constant Tension Turbo Seal Clamps!
    You know you want them...
    818R ICSCC SPM
    Sgt.Gator's Avatar
    Bend, Oregon
    I've updated the original post. We carry a wider selection of Murray clamps now. We've held the pricing the same since 2016 but that is likely to change soon. Thanks for the recent orders!
    818R ICSCC SPM
