Thread: Engine Issue
    Kirkland, WA
    Engine Issue
    I have a engine issue, seemd fine up until about 5K and then will not go much over 5K,here is a video of tach and engine noise, almost sounds like a rev limiter kicking in ...
    http://vid521.photobucket.com/albums...G_3688%206.mp4
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Sgt.Gator's Avatar
    Bend, Oregon
    Certainly does sound like a rev limiter. What tuning solution do you have?
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Kirkland, WA
    Stock at this time, could it have gone into limp mode ? Could it be too cold and needs to get up to a certian temp before it can go over 5 ?
    Tony Nadalin
    Leesburg, VA
    Tony, are you leaving it stock or planning on tuning it with an accessport or rom raider? Either of those tools can look up what the rev limit is set to in the the ECU. Also, you're running the JDM ECU right?
    Kirkland, WA
    I'm running the JDM ECU, I looked at the ECU (through RR) and in Misc-Thresholds the Rev Limit (Fuel Out) is on above 8200 and off below 8000, this was the only RPM limit I could find
    Tony Nadalin
    Kirkland, WA
    Maybe I'm hittig hitting boost cut, and the wastegate arm might be hitting frame, I have to look at that tonight but not sure that would cause this issue
    Tony Nadalin
    Sgt.Gator's Avatar
    Bend, Oregon
    Maybe I'm hitting boost cut, and the wastegate arm might be hitting frame, I have to look at that tonight but not sure that would cause this issue
    The speedo says zero so it looks like you are just revving in neutral. I don't think there is any boost going on with no load. It may be a fail safe in the tune that says with no load to stop the rpms at 5500 so you don't over rev accidentally while sitting still. Does it do this when you are driving?
    818R ICSCC SPM
    Kirkland, WA
    Must be the "launch control" cutting in, all these electroncs ...
    Tony Nadalin
