Love The FE With The Dual Four Barrels!
Also, are those marine flame arrestors topping them off?
Whatever they are, they look good too and really finish off that Monster Mill!
those are stellings and hellings air cleaners like the ones that came on original set ups with two 4s
IMG_8288.JPG closer picture of them
Had to make a trans mount for 4 spd toploader now everything is bolted in. Leveled engine and tightened everything down.
11 months! Wow I was anxious waiting on the transport shipment. Progress looks good, keep it up.
Wanted to finish in one year but a lot of life got in the way
Adam-
She's looking great! I have to say though, that with that monster 482 in there, I envision bits of tire flying wherever you go!!
Congratulations on the progres! It's been fun following along! Looks like the boys have enjoyed the process as well.
I look forward to watching as you finish her up.
The car should have just under 600 HP, kinda matched parts and cam and may have it chassis dyno'd when done, may not care though depending on how it feels. The boys are a big help, since I retired from military I stay home with them and we seem to do everything together, sports, working out, and garage stuff. We also have a 56 ford truck we are going to fix up some year together.
image.jpgheaders in that was a lot of work
image.jpgsmiths gauges in the dash, I always liked the smiths gauges now I have to wire them
image.jpg original 427 type oil filter adapter, I'm trying to get one thing a day done so the car may be done in the next decade
Mark
image.jpg had to cut out center beam for shifter on my top loader to clear
image.jpgsurge tank on
image.jpeg got bored waiting for a couple parts so installed my tredwear billboard kit
image.jpeg leveled car and lowered rear so car wont look higher in back
IMG_8359 3.jpg Car on the move again, moving from maryland to colorado
image.jpeghad new valve covers made with Cobras machined on them
image.jpeg car is finally back in my garage in colorado
Yes I bought them a while ago thinking I would use them to build an aluminum body someday. Seems time is the problem, may never get around to it. The 56 truck in background is ahead of molds
image.jpegbody off for last time hopefully
Has anyone gone out of order on build manual? I don't have wiring harness yet and want to keep going, car wont have many wires, lights, lights for gauges, starter and alternator.
Gauges are smiths and all mechanical, forgot to list fan and ignition. Anything I shouldn't put in that would hinder wiring instalation
image.jpegimage.jpegput oil cooler together in shroud
Sweet! I can't wait to see it running.
.boB "Iron Man"
www.RacingTheExocet.com
Where are you in Colorado springs
From finish line cobra you have to rivit it together around the cooler
.boB "Iron Man"
I'm over in flying horse out of north gate, are many cobra owners in springs?
There are about half dozen or so wandering about the Springs. I don't see them very often, but every now and then.
.boB "Iron Man"
What do most of you do to inside of body, thinking about painting mine flat black?
I'm using Raptor Bed Liner, but am either going Black or Red since it can be tinted.
The stuff is a two part polyurethane product and sprays on.
https://youtu.be/x_QyUZZ0Ys0
A lot of folks use Herculiner since it rolls on.
I've used this stuff before and I think it would be A-Okay too.
https://youtu.be/V9N6M_VCdpk
that looks like what i am going to use, thanks
image.jpegimage.jpegput ac pedals on my brake and clutch
