Hi Folks,
Why Gullwing roof panels? For two reasons. To make it much easier for big and old guys like me to get in and out and for an open top option.
Have the factory leave out the two tubes that run from the top of the rear roll hoop to the windshield hoop. Install one or two tubes in the center and add gusset tubes in the corners. Then cut the roof out on each side and add gutters, hinges at the center and pistons to hold them open. A pair of spring loaded rods on each one to latch them. By removing the hinge and piston pins you have T Tops.
What do you think?
