Results 1 to 5 of 5
Thread: Mendeola Shifter Question
    For those of you who have installed the Mendeola transaxle and used FFR's plastic shifter......did anyone straighten the shifter handle out? It appears right now that it is going to be sticking out to the passenger side of the car quite a bit?
    Shane Vacek
    www.vraptorspeedworks.com
    Member Mendeola Transaxles's Avatar
    Shane,
    Most customers have done the straightening on these as well as shortening.
    Some have recently went to the 818 shifter for a replacement or what we have in use for the non GTM vehicles.
    I would look around the past post there was a write up about doing this.
    Thanks! I think I found the info I needed thanks to your post.
    Shane Vacek
    Member kabacj's Avatar
    Shane. I did this write up on the mod if you want to modify the shifter yourself.
    http://thefactoryfiveforum.com/showt...eferrerid=3030
    You can just buy an aftermarket replacement that is very similar to my mod.
    You probably know that already.
    XTF #2
    build start date June 19 2023
    GTM # 344
    Build Start December 2010
    First track day April 2013
    Thanks, John! I did pretty much what you did with the exception that I never removed the ball from the shaft......I just cut the shaft, cut it down to length and wrapped a damp rag around the ball to protect it from welding spatter and welded the rod back together.
    Shane Vacek
