About mid-Summer, I started to notice a bit of a vibration in my suspension that felt somewhat like a rear wheel out of balance. It would occur around 45 - 50 mph and felt a little like I was running over a slight washboard surface, even when the road was relatively smooth. It seemed worse on roads with more imperfections, but I just figured it was time to maybe get the wheels balanced again.
Well, this past weekend, I picked up a rather large screw in my driver's side rear tire and found something interesting when I pulled it off to get it repaired - the rear Koni shock on that side is fairly wet with oil. I'm guessing that what I was feeling was the oscillation resulting from an undamped corner of the car.
My question for you guys is - do any of you know if there is a place where I can get that shock rebuilt or should I just order a new one from FFR or some other source?
