10
18
Brandon #9196
stack
Tech Tip: Do not close up the driver side foot box until almost last. Be sure to go kart and test all the wiring as it is easier to access with the outside and top panels off. You may find you want to adjust the clutch or brake pedals. Also be sure that the throttle pedal gets you full throttle on the fitech.
stack
Thanks Stack,
I will definately take your advice on that one. I was in the box today and completely disassembled it to install some more parts that came in. I think I am going to pull the parts and paint them to give them all a freshening before final assembly. I found today that the stock mustang pedal is piece of garbage and I will be buying either the FFR pedal or the Russ Thompson pedal. The stocker just cant be saved or made to feel solid and safe. As well as where I want it on the foot box.
Brandon
