0
0
Non Roadster help in the Edmonton area?
Hey is there anyone in the Edmonton area that has access to a dealer level scan tool for a 2002 Envoy? I had to replaces several of the blend door motors in the HVAC system and the reset procedure is not working and now I believe it has to be reset via a proper Scan tool. System is blowing cold on Passenger side and hot on the drivers but with low air movement. Its a little cold driving it right now!
- You may not post replies
- You may not edit your posts
Forum Rules
