FFRDaytona Coupe built with over $78,000 worth of parts and paint. Hasthe best all new parts parts and only 150 shakedown miles since new.Built with a custom built 347 stroker with Victor Jr heads, customCompCams camshaft and topped with a dyno tuned Quick Fuel SS650ANcarb. Wilwood brakes front and rear stop this car hard. It has Konidouble adjustable coil over shocks on all 4 corners. The front has adouble wishbone suspension and the rear has an 8.8 “ Currie builtrear end with Watts linkage and LSD. The car is painted Spectra Micablue with white stripes and number panels. Numbers are vinyl and canbe changed. Vintage Air heat/AC keep you comfortable. The FactoryFive Racing vintage wheels are wrapped with BFGoodrich tires. I havereceipts for all the parts, manuals and instructions for nearly everypart on the car.
- New 347 engine with Victor Jr heads and intake
- Comp Cams hydraulic roller camshaft with roller rockers
- Full MSD ignition with 2 step and ignition retard
- Wilwood 4 piston brakes
- Tremec close ratio TKO transmission
- Quartermaster Bellhousing, clutch and flywheel
- Koni Double Adjustable Shocks
- Autometer Guages
- FFR Halibrand style wheels
- Kirkey Vintage racing seats
- Quick release steering wheel
- Accusump 3qt. Oil accumulator
- Oil to water heat exchanger
- Line Lock
- Simpson 5 point harnesses
- MSD shift and warning lights
- ATL fuel cell
- 760-403-6266 [email protected]
Hop on in
$50,000 OBO 760-403-6266 [email protected]
