0
0
Did you look at all 4 barrels on the LCA's?
They don't show in those pics because you are too tight on the shots.
There is a slight offset on the barrels and they each go a specific way. I would look at those first to see if 1 or more are turned wrong end to the front.
HTH
Thanks for the reply. I just checked them and all four lower barrels are as shown in the book. That is to say the 90 degree side is to the front and rear and the angled sides are to the center of the arrangement.
Tony tells me I should not worry about it and to make rack stops from pvc to limit the turn angle. Anyone have specifics on that little trick? Thanks
Check out "Breeze Automotive", who are vendors on this forum. Part# 21101, Steering Rack Travel Limit Spacer. $9.00 a pair and snap onto the rack under the boot. I'm guessing that their OK for the Hot Rod Rack too.
Neil.
