Bob, have you thought about using a cheap tablet instead, so you have a bigger view? I am planning on doing that with an Arcflash digital dash (whenever I actually get time to install it)
I have a cheap tablet that I was going to use. But the screen just isn't bright enough to make it sunlight readable.
The S7 is close to sunlight readable and waterproof. I can switch it for navigation, or even use it as a phone when not on the track.
Also, no wires needed as it's talking Bluetooth to the SSM adapter.
