Frankb, quick question. Do I see both a thermostat switch and a temperature probe on you engine? And, which is which?The dipstick tube can withstand a bit of bending. With that in mind, the tab should be able to reach one of the threaded holes on the front of the head. Mine is a 351C based build, but Windsor engines have similar holes in the heads.IMG_20150608_063923830a.jpg
