818Kits
Page 7 of 7 FirstFirst ... 567
Results 241 to 253 of 253
Thread: John's EZ36R H6 818R Build
  1. #241
    Finally got my coil pair wires swapped at the ECU plug. Thanks Wayne for that tip, a lot easier than cutting and re-splicing wires. The engine runs perfectly using full sequential and COP, so now I have to try to get James over at MSExtra to re-visit the "Subaru 36-2-2-2 VVT" wheel decoder to change the fuel and ignition triggers to 360 degrees out from their current position.
    I will update this thread with the results from the MegaSquirt develops. I know a couple people are hoping to run these motors, possibly on MegaSquirt ECUs (I'm looking at you flynntuna ).
    MK3.1 Roadster completed 2011
    818R built with EZ36R H6
  2. #242
    San Diego Ca 92106
    Congrats,. But... like they say on the forum, if there's no video it didn't happen
    Not sure yet whether or not I'm going to use Mega-Squirt or Haltech , though I'm leaning toward Haltech.
    My son went to school with a friend of his whose family owns a speed shop. They tune Mega-Squirt, but I also have a friend who is a Haltech dealer. I need to make that decision in a month or so. I
  3. #243
    Senior Member DSR-3's Avatar
    San Jose, CA
    Yea, congrats on the progress! I just got the my DBW working last night, and I'm about to sort the position sensors and cam stuff.* If I had an exhaust I would be starting/go-karting soon!
    *EZ30R, Haltech 2500. So far I'm pretty happy with the Haltech system, features, S/W, etc. My first aftermarket ECU install.
  4. #244
    I was familiar with MegaSquirt as I put it my FFR Roadster. If I was to do it again I think I would opt for the Haltech unit as well, mostly for the DBW support.
  5. #245
    The Aussie ford 4.0 barra motor cable throttle body supposidly direct swap to ez30 second gen. Glad to hear it's up and running full senquential. Are all the cam sensors hall effect? If not I have had good luck with jbperformance VR conditioner board.
  6. #246
    Quote Originally Posted by alpine227 View Post
    All the cam sensors are hall effect and getting solid signals. I currently have a DIY DBW controller board driving the factory throttle body but it lacks ECU idle control, still working on a solution for that.
  7. #247
    Throttle body spacer with iacv flange on it?
  8. #248
    That could work but I am working on a circuit to take the MS IAC stepper position value from the CAN bus and drive the DBW throttle in a small range (0-10% throttle).
  9. #249
    All your H6 818 needs now is a chain drive AWD system so you can keep up with Andy Forrest!
    Owner: Colonel Red Racing
    818R ICSCC SPM and HPDE Rental at Oregon Raceway Park
    2005 Subaru STI Race Car ICSCC ST and SPM, NASA ST3
    Palatov DP4 - ICSCC & SCCA Sports Racer and HPDE Rental at Oregon Raceway Park
    Race Videos at www.facebook.com/ColRedRacing
  10. #250
    Well I left my tuning computer in the garage and apparently Sub zero temps and I assume condensation destroyed the cooling fan so it shuts down after about 20secs of operation. But I had a brief thought of adjusting your trigger offset in tuner studio by 360 degrees instead of rewiring the coils.
  11. #251
    I tried that, didn't work. The firmware only allows a +- 20 degree change for that decoder
  12. #252
    Geesh haltech gives you 720 degrees of offset if I recall. I bumped your thread on the Ms forums worth keeping it towards the top the more it pops up the more likely it is to get addressed. Especially if someone can test and send logs with a working setup.
  13. #253
    Thanks alpine227!
    If anyone following this thread would like to help, please go over to the MS forum and chime in your interest in this motor combination running on MS3. The more interest the more responsive the developers might be.
    http://www.msextra.com/forums/viewto...?f=131&t=67870
Racing Adventures
