61
403
Originally Posted by
flynntuna
I like your solution using the snubber, I'm using the stock motor mounts so I'm going to use the pitch mount bracket. My engine didn't come with the alternator bracket so I'll have to source one.
. Here's a couple of pics using the headers that I got with the car.. Not sure yet if I'll cut these up or start from scratch. It seems that cutting the tubes and add sections to them might work, that would be my first choice, but then again sometimes what seems the easiest route doesn't always pan out.
Are Those are the raptor SC headers? Are they torqued down and clearing the frame?
