Thanks Thanks:  61
Likes Likes:  403
Page 7 of 27 FirstFirst ... 5678917 ... LastLast
Results 241 to 280 of 1072
Thread: John's EZ36R H6 818R Build
  1. #241
    Syracuse, NY
    Finally got my coil pair wires swapped at the ECU plug. Thanks Wayne for that tip, a lot easier than cutting and re-splicing wires. The engine runs perfectly using full sequential and COP, so now I have to try to get James over at MSExtra to re-visit the "Subaru 36-2-2-2 VVT" wheel decoder to change the fuel and ignition triggers to 360 degrees out from their current position.
    I will update this thread with the results from the MegaSquirt developers. I know a couple people are hoping to run these motors, possibly on MegaSquirt ECUs (I'm looking at you flynntuna ).
    MK3.1 Roadster completed 2011
  2. #242
    San Diego Ca 92106
    Congrats,. But... like they say on the forum, if there's no video it didn't happen
    Not sure yet whether or not I'm going to use Mega-Squirt or Haltech , though I'm leaning toward Haltech.
    My son went to school with a friend of his whose family owns a speed shop. They tune Mega-Squirt, but I also have a friend who is a Haltech dealer. I need to make that decision in a month or so. I
  3. #243
    Senior Member DSR-3's Avatar
    San Jose, CA
    Yea, congrats on the progress! I just got the my DBW working last night, and I'm about to sort the position sensors and cam stuff.* If I had an exhaust I would be starting/go-karting soon!
    *EZ30R, Haltech 2500. So far I'm pretty happy with the Haltech system, features, S/W, etc. My first aftermarket ECU install.
  4. #244
    Syracuse, NY
    I was familiar with MegaSquirt as I put it my FFR Roadster. If I was to do it again I think I would opt for the Haltech unit as well, mostly for the DBW support.
  5. #245
    Senior Member alpine227's Avatar
    maine
    The Aussie ford 4.0 barra motor cable throttle body supposidly direct swap to ez30 second gen. Glad to hear it's up and running full senquential. Are all the cam sensors hall effect? If not I have had good luck with jbperformance VR conditioner board.
  6. #246
    Syracuse, NY
    Quote Originally Posted by alpine227 View Post
    All the cam sensors are hall effect and getting solid signals. I currently have a DIY DBW controller board driving the factory throttle body but it lacks ECU idle control, still working on a solution for that.
  7. #247
    maine
    Throttle body spacer with iacv flange on it?
  8. #248
    Syracuse, NY
    That could work but I am working on a circuit to take the MS IAC stepper position value from the CAN bus and drive the DBW throttle in a small range (0-10% throttle).
  9. #249
    Sgt.Gator's Avatar
    Bend, Oregon
    All your H6 818 needs now is a chain drive AWD system so you can keep up with Andy Forrest!
    Owner: Colonel Red Racing
    818R ICSCC SPM
  10. #250
    maine
    Well I left my tuning computer in the garage and apparently Sub zero temps and I assume condensation destroyed the cooling fan so it shuts down after about 20secs of operation. But I had a brief thought of adjusting your trigger offset in tuner studio by 360 degrees instead of rewiring the coils.
  11. #251
    Syracuse, NY
    I tried that, didn't work. The firmware only allows a +- 20 degree change for that decoder
  12. #252
    maine
    Geesh haltech gives you 720 degrees of offset if I recall. I bumped your thread on the Ms forums worth keeping it towards the top the more it pops up the more likely it is to get addressed. Especially if someone can test and send logs with a working setup.
  13. #253
    Syracuse, NY
    Thanks alpine227!
    If anyone following this thread would like to help, please go over to the MS forum and chime in your interest in this motor combination running on MS3. The more interest the more responsive the developers might be.
    http://www.msextra.com/forums/viewto...?f=131&t=67870
  14. #254
    maine
    https://i.imgur.com/eUJ4KmC.jpg
    Here is my crank wheel position with #1 tdc. Right side front piston. (Well rod tdc as the piston aren't installed) I shared over on your MS thread as well. Not sure it that's the same position as yours or not.
  15. #255
    Syracuse, NY
    Thanks for the pic! I need to compare that to the code.
  16. #256
    Syracuse, NY
    Can you check that the timing mark on the front pulley is lined up with the 0 degree timing mark also? Your pic seems to be off one tooth from what the MS code expects.
  17. #257
    maine
    My timing covers are off getting painted basically a bear block at the moment, it could move a few degrees either way as it's a bit hard to tell with no piston on the rod if it's at full tdc or not.
  18. #258
    Syracuse, NY
    Got it, that may be the difference I'm seeing. When you can get a more accurate TDC, can you take another pic of the crank plate. I think it will help me convince the development team there really is a difference they need to account for .
  19. #259
    maine
    Sure I can pop a piston in tomorrow late afternoon and snap a picture for you.
  20. #260
    Syracuse, NY
    After all the screwing around I finally feel vindicated!
    The phase is off 360 degrees as I first thought.
    I went into the source code for an older version of MegaSquirt (1.4.0) as it is the latest source available and flipped the phase in the wheel decoder. After a quick re-compile I flashed it to the ECU and reloaded my tune. The motor fired right up with full sequential fueling and and COP ignition! purred like kitten
    Now I need to get the developers to put in the phase flip code which already exists in other wheel decoders into this one.
  21. #261
    maine
    Really deep dive down the rabbit hole! It's a mystery why Subaru had so many changes in wheel trigger patterns and offsets. I ran into a similar problem with my jdm ej205 with avcs the cam angle sensors were 4 tooth wheels where the us and euro are 4-1 wheels. No support for my wheels
  22. #262
    Syracuse, NY
    Turns out your suggestion on the MS forum of allowing the trigger angle to be 360 degrees or greater would have fixed it! It will most likely be the way they deal with the issue as that code is already in the decoder, they just need to turn it on for the 36-2-2-2 wheels
  23. #263
    San Diego Ca 92106
    Great to hear, a major milestone checked off the list. Congrats
  24. #264
    maine
    Between the motor swap, ECU, brakes, front fender gaps and oil cooling system you are blazing some new paths for sure.
  25. #265
    Syracuse, NY
    Thanks! I'm only doing what a lot of people do with FFR kits, make them their own
    I hope I can help make other's journey a bit smoother.
  26. #266
    Bowling Green, KY
    Great news, congratulations.
  27. #267
    Syracuse, NY
    Joining the rear deck lids
    I decided I wanted to join the two rear deck lids to have a single rear deck panel. After thinking about the best way to join the two panels I finally decided the easiest and most structurally sound method would be to completely cut off the shelf section from the humps. Then sand the back side smooth so there is no lip left over.
    Moving on to the rear deck lid I cut and sanded the mating edge so there was no lip left either. Now the two panels will butt up to each other and be the same thickness. This will make it easier to layup 6 or maybe 8 layers of fiberglass cloth and mat to give strength to the newly formed panel.
    After I glass up the back side I can flip it over and fill any crevice left with resin and gel-coat before final sanding in preparation for paint.
  28. #268
    Syracuse, NY
    Removing the winglets
    On the R models there are these small flappy winglets on the rear humps that are left over when FFR cuts out for the roll bar. They a quite fragile and make it really difficult to get the hump section on and off the car. So I cut them off!
    I made the cut at the location where the TMIC vents are. I plan to glass them in permanently to the side panels.
  29. #269
    Senior Member Rob T's Avatar
    Woodruff, SC
    Interesting idea on the winglets. On my R, there is a push-lock retainer on the front to hold them down. One of them cracked from working them over the roll bar, so I added some more fiberglass underneath to strengthen the stress point. Works for now. Easier to remove with two people.
  30. #270
    Syracuse, NY
    Yes, I wanted to be able to easily remove the rear deck lid by myself. The winglets made it difficult to do that.
  31. #271
    Bowling Green, KY
    Did some thing similar. Thought about riveting to the quarter fender but decided I want to be able to remove it if I needed the space to work on something.
    I don't have a problem removing it by myself.
  32. #272
    Mar 2014
    Oakley, CA
    You're inspiring me to do the same on my R. My roll cage modification project has spilled over into a body-test-fit project. Very interested to see more detail on the fiberglass work. Thanks for the pictures!!
  33. #273
    Syracuse, NY
    Mitch, I see what looks like 10-32 button head screws holding the winglet in place. I assume you fabricated some brackets, but where did you mount those too? Any pics?
    Quote Originally Posted by Zach34 View Post
    Thanks Zach, I'm very impressed with your door frame mods. You got skills
    I'll try to keep posting pics of the body mods as they happen. There are many more left to do!
  34. #274
    Syracuse, NY
    Joining the rear deck lids Part 2
    To prepare for laying fiberglass I first taped off the top side with Gorilla Tape to give me a backing in the gap between the panels. Then I secured 6 strips between the two sections to ensure the top surfaces would be aligned correctly. I cut the strips out of the pieces of fiberglass body removed when cutting out the vents in the hood. Good use of scrap material!
    After flipping the two panels over, I sanded about 5 inches around the gap to be fiber-glassed. The round black object you see on the right hump is a solid piece of steel I'm using to weigh that side down as the panel is a bit warped. I hope to lay the first round of cloth and mat tomorrow.
  35. #275
    Bowling Green, KY
    John, The front aluminum bracket is riveted to the door the one by the main hoop is bolted to the hoop. Sorry no pictures. I might be able to get a picture of the rear mount but it will be a week, head out west to do some skiing.
  36. #276
    This is what we did, but it does take two people to remove and install, with the wing on.
  37. #277
    Syracuse, NY
    Enlarging the side vents
    I previously cut the side vents to make them deeper in hopes of getting more air flow. Now I need to fiberglass up the gap to make the panels look like they were designed that way. I added 1.5 inches depth to each vent, measured approximately half way up the vent. But to get the top to look right I had to cut out the entire top self. This meant I need to create a flat surface I could layup fiberglass against until it cured. I ended up cutting out some wood shapes and clamped / taped them in place while I laid the glass. It made a nice smooth flat surface to work on.
    The bottom was easier since the gap was smaller and the surfaces to be joined were flat. I just used duct tape between the gap laid the glass against that Here is the side panel after removing the wood mold and duct tape.
    After it cures in a few days I can cut out the middle vent section and bondo any rough spots to make the transitions smooth.
  38. #278
    Syracuse, NY
    Extra venting thru the side pods
    Earlier I cut openings in the front of the side pods to allow some high pressure air from the front wheel wells to escape thru the hollow side pods and exit into the engine bay. Hopefully adding some cooling back there.
    To keep large debris and pieces of rubber from entering, I added some stainless steel mesh I had from a previous project. I secured the mesh with clear silicone. Here its held in place with wire and some welding rod while the silicone cures.
  39. #279
    south-central CT
    Nice! Interesting. I refer you to my post about my bodywork and lightening.
  40. #280
    Mar 2014
    Oakley, CA
    Nice job on the wood forms.
