'15 IRS half shaft removal
Has anyone installed a half-shaft into the diff then removed it? There is a spring clip on the end of the shaft that locks it into the diff when installed. It's the equivalent of a c-clip on some semi-floating rear axles except better since it's self-installing and doesn't require the diff off to get it on. What I can't tell of the '15 design is whether you DO have to get into the diff to get the half-shaft removed.
I installed one then decided to remove it to paint the bare metal with a clear coat. I don't want to drain and remove the diff cover since it came from Ford Performance with fluid in it. But for the life of me I can't get the shaft back out since that spring clip is holding it in. Part of it is that I have broken ribs and can't pull very hard at the moment. But I used a slide hammer type action and all that happens is the upper cv joint takes the brunt of the action. I tried prying it but just bent the dust plate/tabs.
Is the spring clip just seated that well of do you have to pinch it from the inside to get the shaft out?
-TJ
Posted also in the other forum: No, you don't have to take the diff apart. There's nothing inside to release. It's being held by a compressed spring clip. Normal process is to pry it out between the center section housing and the CV joint. Like in this video at roughly 4:10. 2015-2017 Mustang Ford Racing Rear Half Shaft Upgrade Kit Installation - YouTube. I haven't taken the new assembly apart once it was installed. But when I received my new take-out 2015 IRS assembly, it was the whole IRS pallet including the stock CV axles. They both popped out with a little bit of leverage like shown. I wouldn't be using a slide hammer and pulling on the CV joints themselves. No reason to. Good luck.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Paul covered that nicely so I have nothing to add. I will add on a another IRS topic that when I got my irs I called FFR and then Ford inquiring to verify the unit was full of fluid. Every person I spoke with gave me a different answer. The one that bothered me the most was "I think they fill it part way for shipping." I decided to do a fluid swap just to be sure. In the end it seemed like I put about the same amount back in as I took out. I do feel a little better knowing for sure it is serviced properly. Just something to consider. Maybe you have seen some more definitive information that it comes full and ready to use.
http://thefactoryfiveforum.com/showt...e-build-thread
