Shield & Sensor Ground Joint Connector
Can this connector be deleted? It's called ground joint connector (B83 on 2002 WRX wiring diagram) but according to the diagram, none of the pins are actually connected to the ground. They are just bunch of sensor wires ganged together. Are those trully grounds or just some sort of test points? Would sensors still work if I cut that connector out? Thanks.
