NAZ
You should also be asking if the wheels are centered in the rear fenders on the IRS. They're not with the solid axle version which limits tire size even more.
They moved the wheel back 1/2" with the new IRS so while it's still not centered it's not as obvious or limiting as the live axle versions.
DB
