0
0
Wheel Recommendations for Bicycle Fenders
So I saw this post...
http://thefactoryfiveforum.com/showt...ons-33-Hot-Rod
and it says that with fenders the suggested max tire size is
Front maximum wheel width and Backspacing: 9.00” with 5.50” Backspace
Front maximum tire width: 255mm
Rear maximum wheel width and Backspacing: 11.00” with 6.00” Backspace
Rear maximum tire width: 315mm
Front / Rear maximum tire diameter: 25.7”
Is this true for the Bicycle Fender as well. The post above is from 2011 and I don't know when the bicycle fenders came out. I was just wondering if I could go with a larger overall diameter than 25.7" with the bicycle fenders.
Tim
