I am tackling the front alignment and have a few quick questions. These are all preliminary as the body is not on yet, but since i plan to drive it a bit before then, i thought i may as well practice. Front toe is 1/8 and camber is -0.5. Left front wheel caster is + 7-8 degrees, while the right front caster goes negative and I run out of adjustment. I'm using the Fastrax Camber and Caster tool which seems decent. And, yes, I added an extension to the vertical arm.
I noticed that the front left lower ball joint is forward of the left upper ball joint, while the front right lower ball joint is aft of the right upper ball joint. This is where I'm a bit confused as I thought that with positive camber, the lower ball joints would be aft of the uppers? Not correct? Also, why are my lowers not both fore or aft?
