Thread: Best solution "intank pump" with carb
Hybrid View
    Palm Bay FL
    Wondering what you folks suggest for the in tank pump, or deletion , to run a carb with mechanical pump?
    No reason to have an in-tank pump if you're running a carb with mechanical pump. You just need the fuel pickup for the tank without the pump mounting. Commonly available part and very straightforward. Breeze has a couple options. There are others.
    http://www.breezeautomotive.com/details.php?prod_id=300
    http://www.breezeautomotive.com/deta...p?prod_id=1103
    Bourne-Cape Cod, MA
    The pickup,comes with the complete kit. If that's what you have purchased?
    FFinisher/AKA RE63
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    I'm running the factory mustang EFI in-tank-pump, and will be installing a Holley 12-803BP fuel pressure regulator.
    Senior Member stack's Avatar
    Macedon, NY
    Maybe check the FFcars forum archives. I thought there was an Chevy S10 fuel pump that bolted in the mustang bracket and was maybe 10psi that could be used for carb. It has been years since I have seen this question though.
    stack
    FFR MKI Roadster FFR2202K Built in 2000 sold
    FFR Hot Rod #39 under construction
    Macedon, NY
    Unconventional Builder Joee's Avatar
    Hatboro PA
    Quote Originally Posted by stack View Post
    Yup thats the one I have been running mine for 2 yrs now. FYI if you are going to use stock EFI pump, regulator, and return lines it wont work with 5/16 supply and 1/4 return as supplied by FFR. Been there done that ergo why I have that pump. In order to be successful with a regulator you need a return line as big as supply ideally run 3/8 to regulator and back to tank. I decided to swap out pumps instead of swapping out fuel lines.
    Roadster Mk3 5294, 302 Comp XE276HR cam, AFR 185 heads, 650 Quick fuel carb, Air Gap intake, T-5 3.55 gear Levy Upper & Lower Front and Rear control arms Purch Jan 2008 Tagged Mar 2012 Best ET 12.14 @113** SOLD 4/8/18 **
    YouTube Videos: Current performance - https://www.youtube.com/channel/UC7c...86xO3U4l4RtVMQ Older build - http://www.youtube.com/user/joeembery#p/u My Pics:
    http://s207.photobucket.com/user/Joe...?sort=6&page=1
    Th OP specifically said he was running a carb with mechanical pump, and wanted to know what to do with the in-tank EFI pump. Apparently he wasn't aware he could have a pick-up without a pump. No reason to make it any more complicated than that.
