Results 1 to 10 of 10
Thread: Murphy's Garage Laws (and others)
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Since Mr. Murphy seems to stick his nose into everything else, and he's visited me more than once or twice. I found this: Murphy's Garage Law......
    Regardless of the number of bins, organizers, coffee cans etc. full of nuts/bolts/screws available, you won’t have the required item, or enough of them to complete the task.
    Anyone have any others?
    Ray
    "The I.E." SoCal
    Speed X Force does not equal distance when you drop a wrench or part on the floor.
    __________________________
    Regardless of your organizational ability, when needing a Phillips screw driver you will only find slot type or vise versa!
    WEK
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    A dropped fastener will always travel just far enough to stop under any object that makes it difficult to find or reach.
    Later,
    Mk3.1 #7074
    Super Moderator
    Ray's Avatar
    La Mesa, California
    The second part of this is:
    When you drop a tool or fastener in the engine bay, the chance of it actually reaching the ground is dependent on the time of day, your fatigue level and the phase of the moon.
    Ray
    Super Moderator
    Ray's Avatar
    La Mesa, California
    If you treat your car like a race car, then it will develop expensive race car problems.
    The fastest way to make 1-million dollars in racing, is to start with 5-million dollars.
    Ray
    2bking's Avatar
    Garland, Texas
    No matter how many sets of tools you have, they all will be missing the tool you need now.
    You can't get something clean without getting something dirty.
    King
    Most garage build projects require an Ace Hardware store nearby.
    Northern VA
    I don't need gloves for this. Blood everywhere.
    Master Builder
    Long Island, NY
    Quote Originally Posted by scottiec View Post
    You drop a screw, see it, can't reach it, get magnet, find out is stainless, DARN.
    Kenny
